SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
SOURCE: Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
