20 Most Recent Air Hogs Reflex Micro Helicopter Questions & Answers
Take it back or consider buying one that really works. These are not much more than really cheap toys. I have two and if I can get one minute of straight flight I am lucky.
Air Hogs Reflex... | Answered on Oct 02, 2012
same thing
Air Hogs Reflex... | Answered on Sep 18, 2011
Right here is the support site. http://www.airhogs.com/#/need_help
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
Check the tail rotor and shaft for damage or hair and fibers wrapped around it. It will slow the tail rotor a lot causing the spin.
More help here. mailto:support@airhogs.com and here.. http://my.airhogs.com/
Air Hogs Reflex... | Answered on Jun 14, 2011
sounds like the shaft has been jarred loose causeing the fly bar to exceed its limit. return for refund or exchange, or if you feel brave carefully crazy glue the flybar housing to the shaft so that the bar it self still operates but has no left right play in it... worked for one of the 4 i had....
Air Hogs Reflex... | Answered on May 11, 2011
replace the tx batteries, then make sure the room is free of any and all other ir signals. failing that, return for refund or replacement
the light on the front of the heli blinks green red green gred then when its fully charged it just blinks green. also make sure the tx is turn to the charge setting which is all the way down
adjust the trim, turn the knob the oppside direction the nose of the heli is spinning, if that dont work then either your weight is wronge or you have trash in your gears
We had a simular problem - my son's unit was also stuck in picture taken mode - After contacting Spin Master (1-800-622-8339) it would appear that this is a known issue and they will replace the defective unit for free with proof of purchase.
You could also try to fully drain the unit (by leaving it on) and then re-charging it - apparently this has worked for some people.
By rule of thumb, rechargeable batteries, should be charged for 12~14 hours OFF FROM THE SHELF. Then, 3~4 hours thereafter. This has proven to prolong re-chargeable battery's life.
TIP: observe how long the battery last first. so that you'll know when to charge again.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Air Hogs Reflex... | Answered on May 05, 2011
1. Please check your controller and ALL other batteries inside your RC units. 2. If they seem ok but not new, ensure to change them out for new ones 3. Check your relays, they sit inside your Hawk and control HOW MUCH your unit will accelerate, trim, lift, turn, etc. 4. You may check these by removing a few simple panels covering the immediate motor areas. 5. The relays will have an adjustment knob, gear shifter, or position device which will GREATER affect how much acceleration your RC gets when you increase or decrease it from your remote 6. On your RC gas type, always check to ensure that enough exists but never over fill 7. On electric type, ensure that no leakage is present, no overheating, and no obvious damage from a prior flight 8. Check your lift blades, sometimes they become damaged during flight and will need to be adjusted, repaired, and in extreme cases, replaced for new ones
Air Hogs Reflex... | Answered on Jan 28, 2011
Thank you for your question. From my research, it appears that the Air Hogs R/C Reflex does not have video capabilities. The Air Hogs Hawk Eye does have video and picture taking capabilities. Look at your Air Hog to determine which one you in fact have. Here is a link to video tutorials for all of the Air Hog products that may help you: http://www.airhogs.com/#/need_help/reflex. The link is set to the Reflex but you can change your product selection to any product at this link.
If you have the Hawk Eye, here is a link to the instructions: http://www.spinmaster.com/files/instructions/AH_Hawk_Eye.pdf. It is not possible to look through the camera. You can however, take pictures and videos during flight. Download the images on your computer to see the images you caught. To download, plug the small end on the USB plug (included with your Air Hog) to the product and the large end to your computers USB plug (this is how you charge the Air Hog, too). In your computer's Windows Explorer, you will see your Air Hog connected and can copy the images to the computer. Remember to remove the images from the Air Hog to free up space for new images. Always remember to pick on the eject button on your computer for the Air Hog before unplugging it from the computer. Take note that the videos do not record sound. If you access www.airhogs.com, you can register and download free editing software to add cool images, sounds and words to your videos and pictures. You will also be able to share them with others.
If you need additional assistance, you can contact Air Hogs Flight Training Center at 1-800-622-8339.
I hope this helped. I would appreciate your taking the time to rate my assistance with FixYa. Enjoy your flight!
Air Hogs Reflex... | Answered on Jan 23, 2011
We need more detail Kumirai, what is it that is actually broken on your plane? or is it a helicopter like your picture suggest?
Air Hogs Reflex... | Answered on Jan 12, 2011
Go here for help / parts etc.. http://www.airhogs.com/home.html#/need_help
Air Hogs Reflex... | Answered on Dec 15, 2010
Air Hogs Reflex Micro Helicopter Logo
33 questions posted
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
View Most Popular
Air Hogs Toys
  • Air Hogs Toys
Most Popular Question
problem recived toy many
  • Toys
