Is your radiator cooling fan operating when the A/C is turned on? The cooling fan should be running at all times with the A/C on. If it does not, then your problem is being caused by a bad cooling fan motor, a bad cooling fan relay, a broken fan motor circuit, or broken fan control circuit.
YOU HAVE TO REPLACE COOLANT FAN IF BROKEN. YOU NEED TO CHECK AND SEE WHAT CAUSE FAN TO BREAK.MAKE SURE YOU HAVE NO OBSTRUCTION OR SOMETHING RUBBING INTO FAN CAUSING FAN BLADES TO GET BROKEN.
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
