The easiest way is to go to the manufacturer website and look under support for an upgraded driver. I will tell you that when where I worked upgraded to Win7 we had many HP scanners that would not work with 7 and there were no drivers available. If you run into that then start looking on the manufacturers forums to see if someone has written a homegrown driver.
After upgrading from Windows XP to Windows 7 you probably need to go to the Epson website look up the model printer and download the specific software and drivers for Windows 7 this should correct your problem install that new software
It's good that you have the recovery cds. Do NOT reformat the hard drive. Restore with the cds so you'll have a clean install . You will need to have any software cds that did not come with the original pc in order for them to rebuild the registry entries. That is the easiest way because there won't be any left over files from Windows 7 after you restore to XP.
Right click on desktop, go to 'graphics options' and then to 'output to'. Go to 'clone displays' and select 'monitor + built-in display'
It helps to have the TV plugged into the VGA port on your notebook before you turn that on.
Hi, There is most likely an incompatibility issue with windows 7. Have you tried reloading your XP webcam driver? H.P. currently has no drivers available for your Pavilion for windows 7. Keep referring back to www.hp.com to check as they are working on developing drivers for models which meet the minimum hardware requirements. Best wishes, Graemevm
