the problem is when i open the computer always need to press f1 and display have not apear untill open the computer, please help me about thatthe problem is when i open the computer always need to press f1 and display have not apear untill open the computer, please help me about that
You can't post conmments that contain an email address.
Did you change something in the bios? Enter the BIOS and check the Power Management or just Power settings and disable ACPI. This should solve the problem.Windows would again find new hardware and then should work normally.If ACPI not found under power it could also be under Advanced tab. Did you install any new hardware?.The hardware might be non ACPI compliant hence the error.
Have you installed something new on your board? What this is telling you is that the ACPI (Advanced Configuration and Power Interface) does not work with something on the board. Or check your bios setting and make sure you have ACPI turned on.
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Look in your bios & see if you can disable the ACPI, (which you should be able too do. Finish installing your OS. Than update the OS. After completing all updates re-enter your bios & enable the ACPI. You should not get that error message after re-start.
Boards that support ACPI will get this error during a fresh install untill they get windows updated. All OS's
Post back if this did not help! It worked for me.
Please vote..
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact
your system vendor for an updated bios. If you are unable to obtain an
updated bios or the latest bios supplied by your vendor is not ACPI
compliant, you can turn off ACPI mode during text mode setup. To do
this, simply press the F7 key when you are prompted to install storage
drivers. The system will not notify you that the F7 key was pressed -
it will silently disable ACPI and allow you to continue your
installation."
