Question about Motorola Mobility S9 Headphones
My motorola s9 is not charging - Motorola Mobility S9 Headphones
  • 30 Answers
Make sure you're using the right USB charger. Just because the plug is similar in shape doesn't mean the correct voltage is getting to the headphones.
Posted on Aug 30, 2010
My motorola s9 headphones won't charge
Have you tried plugging into a different charger to ensure it is not your charger?
Mark
Motorola Support
Jun 29, 2014 | Motorola Mobility S9 Headphones
Recently i have purchased Motorola S9 blutooth head set. Kindly let me know what type of motorolla charger to be used 1.5amp or 2 amp since there are 2 chargers available. And also while charging, within...
Bluetooth headsets, like many portable devices can be charged on a USB port on a computer, which supply less than 1A, so either charger would be suitable.
Looking at the manual, a full charge should take two hours, so half an hour seems a little quick.
Perhaps it was part charged?
You could see if you can listen to music for six hours on a charge, and if so how long it takes to charge then.
The manual can be found here.S9 user guide - Motorola
Feb 14, 2011 | Motorola Mobility S9 Headphones
My s9 headphone not on of work tell me wath i do
make sure you charge the S9 using a motorola mini usb AC charger or a mini USB cord plugged into a live port.
press and hold the circle vertical bar until the light is steady blue and pair it with your bluetooth device. you only have two buttons at the rear of the device under the motorola logo.
Aug 28, 2010 | Motorola Mobility S9 Headphones
Motorola S9-HD will not turn on or charge
try a new battery, and if you already have, check the copper contacts on the battery and phone for corrosion, otherwise the problem may be internal.
Jan 20, 2010 | Motorola Mobility S9 Headphones
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Sep 15, 2009 | Motorola Mobility S9 Headphones
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
My phone can't start up.
try press *#power key at the same time if you see your phone in bootloader mode. your phone can be recover. let me know so i can give more tips
Sep 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility S9 Headphones Logo
678 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
