Question about Motorola Mobility S9 Headphones
Motorola s9 headset not charging
I just received a pair of motorola s9 bluetooth headphones i ordered on ebay. they are supposed to be new but will not accept a charge. I plug it in and the red light turns on for about 5 seconds then turns off. I let it sit for about 30 minutes with no change. the manual said the light should stay on when it is charging. the device will not power up when I unplug it.
Posted by joegowdy on
  • Anonymous Mar 29, 2014
    The Charging light won't go off on my Photive PH-BTX6 Bluetooth Headphones after they have charged up when i disconnect the charging cable and plug it back up right then the light does not come on Photive say that the Red light is suppose to go out indicating that the headphones are charged
Anonymous
    New Friend:
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Posted on Nov 20, 2009
Anonymous
Are you using the Motorola brand charger or some off brand? I guess there is a chip in the Motorola brand charger that communicates w/ the headset, some better brands of chargers will work, but no-name cheapo chargers prolly don't have the chip & won't charge the device. That's been my experience with the headset.
Posted on Oct 07, 2009
Anonymous
    New Friend:
I have the same problem. I tried the 2 solutions above, unfortunately it did not work. I read that the baatery inside is a lithium battery, NON REPLACABLE by the user. I search now for a repair centre, perhaps they will be able to fix it.
Posted on Nov 29, 2009
  • 1 more comment
  • edwards653 Apr 10, 2012
    Mine flash gene twice then nothing, tried 3 chargers and USB from computer but still nothing. I bought them as new old stock, any one any ideas?....please!?
  • har67212_fac
    har67212_fac Dec 20, 2012
    Mine was doing the two green flash too. I plugged it into a computer USB port and it stopped and started charging. You might try that.
  • har67212_fac
    Mine had the same two greenflash problem.I plugged the S9 into a USB port on my computer and it started charging normally. You might try that.
I have metro pcs phone service and a motorola s9 bluetooth headset i cant get the passcode.
Press and hold the power key (under the red cover) longer than the time required to turn it on, until its indicator light is alternately flashing in red and blue. It is in pairing mode (discoverable) now. Then, make your phone's bluetooth application search for new devices. After a little while, the S9 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the S9 should enter the stand-by mode. There could be such an indicaton in your phone too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Mar 07, 2011 | Motorola Mobility S9 Headphones
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Sep 15, 2009 | Motorola Mobility S9 Headphones
I have lost one of the earbuds from my S9
ebay
http://shop.ebay.co.uk/i.html?_nkw=motorola+s9+earbud+&_cqr=true&_nkwusc=motorolla+s9+earbud&_rdc=1
Jul 02, 2009 | Motorola Mobility S9 Headphones
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 10, 2009 | Motorola Mobility S9 Headphones
Trying to connect motorola s9hd to the laptop
assuming you have bluetooth installed on your laptop,
1) you have to disable the bluetooth pairing of your s9 with another device that you may have paired with it earlier - like a mobile phone. disconnect previously paired devices first.
2) turn on the bluetooth feature on your pc and ask it to "search" for devices. assuming your s9 is on standby, your pc should be able to "locate" and pair with it assuming the s9 is within an arms length distance from the computer.
3) make sure that the s9 is completely charged to eliminate that power issues as well
Apr 07, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Iam looking for replacement earbuds for my motorola s9 bluetooth headset. geozep0
I did exactly what geozep0 indicated in his comment with similar successful results. I called the Motorola customer service number: 1-866-289-6686. Per the representative I spoke with, Motorola's standard warranty policy covers the entire unit (including the earbuds) for one year from the date of purchase.
They are sending me new earbuds free of charge.
Success!
Feb 23, 2009 | Motorola Mobility S9 Headphones
PAIR KEY FOR MOTOROLA s9
Bluetooth headsets have their passkey hardcoded by their manufacturers. So, I'm afraid it is not suitable to be changed. However, once any two bluetooth devices are paired, their link is encrypted. You see, you put your headset in pairing mode only when you want to pair it to a specific device of yours (i.e. phone, PC, etc.). Once they are paired to each other, third devices won't be able to get into that connection.
Just my 2 cents...
Regards, Carlos
Feb 21, 2009 | Motorola Mobility S9 Headphones
Pairing Motorola S9 headset with PC
i have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Jan 25, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola Mobility S9 Headphones Logo
5,274 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
john h
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
