Question about Motorola Mobility S9 Headphones
How do I reset s9....the green light stays on constantly and I cannot connect at all.
Posted by jdenneynd on
Anonymous
  • 3 Answers
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Posted on Jan 11, 2010
Anonymous
I just fixed mine by having the charger plugged in the headset and unplugging the charger from the AC. The green light went out and then i was able to connect to the bluetooth device.
Posted on Apr 02, 2010
sibyl3
    New Friend:
I tried this. Totally worked! Just plug the charger into the headset and pull the charger plug out of the wall. Light goes off! Excellent!
Posted on Oct 18, 2011
Anonymous
    New Friend:
I have had the same problem with two different headsets. Fully charged, as the light can stay on for DAYS, but I cannot connect or turn it on. ARGH!
Posted on Nov 06, 2009
Wont turn on
2 days old and defective return for refund or replacement
Jul 12, 2017 | Motorola Mobility S9 Headphones
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How do I pair my s9 bluetooth headset with my
do you have the adapter that makes your ipod nano have bluetooth?
im guessing you do so
turn on the bluetooth adapter on the ipod
mod the power button on the motorolla s9 untill blue light is constantly on
from the ipod select the bluethooth options and select the headset
use the password 0000
Apr 29, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
Dec 10, 2009 | Motorola Mobility S9 Headphones
Hear sound out of computer rather then earphone. Has worked great up until now. Blue light will not stay on. When charging light is red.
when the red light is on while charging it means it is at less than 25% charge let it charge until the light is green
then tryy connecting it to the computer
Dec 01, 2009 | Motorola Mobility S9 Headphones
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Nikon coolpix s9 flickering problem
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
Apr 12, 2009 | Nikon COOLPIX S9 Digital Camera
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Router wpn824 stops working green lights all come on and hold
Hi there, if all the light come on and you only have one or no ethernet/lan cables connected then there is a fault with the router i`m afraid and you need to replace or return it assuming its still under warranty... sorry
Dec 12, 2008 | NetGear RangeMax WPN824 Wireless Router...
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Motorola Mobility S9 Headphones Logo
7,613 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
john h
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
