SOURCE: Miele Model G 692 SCI
The inlet/drain light also comes on when there is water in the base pan. There is a float switch that triggers this and over time if water has collected in the base pan the float switch can stick. Pull out the dishwasher and tilt it towards to back. If there is any water in the base pan it will come out. To be thorough, put the machine on it's back and remove the base pan (4 screws by the feet), the float switch is a circular plastic casing with a polystyrene float in it. It comes apart for servicing, the float can jam if there is any rubbish in the water.
SOURCE: 3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
SOURCE: miele g898 sci plus won't start (type HG01)
Button wont stay in - lights up but nothing happens. Machine three and a half years old.
SOURCE: the end start and top solo indicators flash
Please check out if you have wet area in the bottom housing
