SOURCE: i can,t print
this usually indicates there is a problem with the cartridge, check the bottom of each cartridge and see if the colour barcodes are intact and ensure you are not trying to start the machine with the lid up as too much light coming in will also cause the problem when reading the coloured barcodes on the bottom of each cartridge
SOURCE: BRAVO PRIMERA 11 ERROR CD PUBLISHER
The Publisher has a cartridge problem. Check to make certain that the cartridges are installed correctly and that the bar code labels on the underside of the cartridge are not damaged.
SOURCE: canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
SOURCE: I got cut off last time so we will try again.
Does the printer head have a cleaning feature in the software? If it does I would try that to see if it improves your printing.
Problem solved. It turned out to be a dvd problem. A stack of recently bought dvd's appears to have different (quality of) printing surfaces. As a weird coincidence up to last friday I hit all the right ones at the wrong moment and vice versa.
Turned out to be a dvd problem. Different (quality of) printing surfaces within a stack of 100 dvd's. Just hitting the right ones at the wrong time and vice versa
