SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are: - bad door switches or door switch mounts At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information. See our listing here on FixYa: http://tinyurl.com/yzjozk
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
SOURCE: Microwave Sharp carousel Model R3A36 keypad not working
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
SOURCE: whirlpool gold microwave over range model gh9184lq-2
F3H I assume? That means your humidity sensor has failed.
There
should be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our site, we now have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the range lights and hood fan never work, then that's a problem on the control board.
We see (and repair) this a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: no display, no light, no fan, microwave dead!
There
should be a "mini-manual" (tech sheet) hidden inside the unit behind the
At
our Web site, we have a video available showing how to remove a typical
It
may be the fuse, which is located in the upper area behind the control panel.
If
the fuse is good, it may be an open thermostat or thermal cutout (TCO)
/ thermal fuse on or near the magnetron or on top of the cavity / body
of the oven.
(Don't be confused by the base or hood thermostat, which is on the floor of the chassis. It will read normally open).
The fuse and magnetron thermostat can be checked with out taking the oven down from the wall, but if you need to check the oven thermostat, you will need to pull it from the wall.
To help with that, you can download Whirlpool owner's manuals and installation instructions here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
SOURCE: wall mounting needed for a top mount microwave/hood combination
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
