HP PSC 1350v All-In-One InkJet Printer Logo
Posted on May 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to scan from printer to Word Document.
When I push the scan button, nothing happens other than the ON/Resume light blinking about 10 times.
harsha gayan
Level 2:
Sergeant:
Champion:
  • Expert 246 Answers
  • Posted on Jul 29, 2008
harsha gayan
Expert
Level 2:
Sergeant:
Champion:
Answers
246
Questions
0
Helped
65874
Points
598
First you uninstall the drivers
Then reinstall the driver
Says to reset color ink tank. put a new one in and says same. reset many times nothing happens
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
I want to scan a photo. When I push the "scan" button, the "on/resume" button starts to blink, and nothing happens
Hi Sturdygirrrl
Read your issue.
Please try the following...
1. Unplug the Power cable.
2. Press and hold down the On/ Resume Button for the next 35 seconds.
3. then release the button.
4. Plugin the power cable and the power on the printer.
5. Check your issue again.
Thanks & Regards
Ashish Rohilla
3helpful
2answers
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
  • Before resetting printer canon iP90, start with printer power off.
  • Green LED indicator will blinking and then stopped blinking.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
I am trying to scan a printed document using my HP PSC 1210xi all-in-one, and when I press the scan button, the On/Resume light will flash for a few seconds, then go solid. Nothing else happens. How do I...
First load the software tha tcome with you all in one in the laptop.
then scan from the laptop instead of from the printer.
Use the all in one icon on the laptop instead.
. then it wil lgive you the optiont o send it toE/mail or where.
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
I have to get a printout... When I went to my IP2200, I found several pages jammed. I simply pulled them out and rebundled the paper and set them in the feed tray. I then pushed the resume button, which...
Hi. In such situations it is best to reset the printer.
This procedure resets canon iP1200 /iP1600 / iP2200 printers.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
1helpful
2answers
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
Printer will not respond
Canon S330 Turn off printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
k24674
Grand Canyon Tech
Grand Canyon Tech
