Cars & Co 1976 Ford Gran Torino "Starsky  Hutch" 118 Diecast Car Logo
Posted on Aug 22, 2010
My truck is to high - Cars & Co 1976 Ford Gran Torino "Starsky Hutch" 118 Diecast Car
My high beams won't work on 2008 cats Cadillac the brights are showing in dash but go to high beam
It is likely a blown high beam fuse - check your fuse box. Or it could be the high beam relay - but I would check the fuse first
Idles high from first to second gear .
Define idles high like its going high rpms before shifting or the engine itself is high reving if its high rpming when shifting its mostly you tranny going out you can try tranny fix oil I used it on my truck when it had shifting problems and ive had no problems since it takes a few days to work though and if its the motor itself it could be a lot of things but I dont know much of the problem based on what you told us
2answers
High fuel consumption
name how high. is high. RATES?
keep in mind MPG varies by load , driver and tire pressure.
High beams stay on with low beams fuso truck fesp
Change the high beam relay it has welded on
My high beams dont work.
high beam switch is faulty look at getting a new stalk.....
I put my 2000 escalade in 4 wheel low last night; and now I cannot get it switched back to 2 wheel high. I will not go above 50 miles an hour when I drive it. When I press the 2 wheel high button it...
start truck leave in park press 2 wheel high button put truck in drive move truck,check for being in 2 wheel high, if still in 4 wheel low have switch and shift solenoid checked
No high speed cooling fans 1996 honda accord low speed only
High speed fans only come one for high temp or high a/c pressure. Will be hard to tell if they work on high.
TRUCK BLOWS A LOT OF HEADLIGHTS...BOTH SIDES, ANY IDEAS WHERE TO START
usually due to high resistance causing high voltage. Check voltage at headlamp. should be between 12 & 14 volts.
check headlamp grounds. if loose or corroded, it will cause high current draw.
Top Cars & Co Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
