Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
Posted on May 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't get cold enough
Temp alarm is on and won't go away. it blows cool air but not cold air.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
158
Points
Anonymous
Level 3:
Genius:
  • Master 1,073 Answers
  • Posted on May 05, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1073
Questions
0
Helped
392276
Points
2842
Sounds like a sealed system problem lack of freon, possible tubing leak
I have a Frigidaire upright LFFU1465 and it is on but not blowing cold air.
If the condenser is clean and the temperature rising, the freezer is short of gas
Apr 13, 2012 • Freezers
3answers
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 • Freezers
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
13 months old Kenmore compressor very hot.
lacdoi,
huuum At your service!
You said,
The warranty just ran out, Sears came out told me needs a control board ($210 for just labor to replace) not sure about part price. I though a new freezer is about twice his labor and parts, so I sent him away minus $65.
I did some troubleshooting today, pull the plug for 2 days. Plug it in, temp alarm goes on all the time. Turn alarm off, left the freezer running for 4hrs.
Not cold at all, some cool air. Fan is on, compressor is on (can hear humming noise and is vibrating). Compressor is very hot to the touch, could burn finger.
Should I call Sears again, wonder how much to fix all the problem? Or just give up, look for another brand new one (not Kenmore).
MY ADVICE:
Sounds like a big repair bill and multiple problems
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
Replace it.
You will be fine
Bless You huuum
Please give me the best rating for my fine advice before you sign off.
Thank you
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 • Freezers
Kenmore upright freezer
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
2answers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
