Computers & Internet Logo
Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have replaced the dvd rom/cd rw with dvd rw, but i am unable to write or burn dvds..........it still only possible with cds
Nanny
Level 3:
Genius:
  • Computers & ... Master 2,351 Answers
  • Posted on May 06, 2019
Nanny
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989368
Points
7262
You also need to download a dvd burning software on your computer. You cannot just copy and paste the movies to the DVD discs. You could try Leawo DVD Creator which can support many input formats and you could even create 3D effect.
Anonymous
Level 3:
  • Master 560 Answers
  • Posted on Aug 19, 2010
Anonymous
Master
Level 3:
Answers
560
Questions
0
Helped
172740
Points
1663
Hi. You need to install the burning software that came with your DVD writer to make sure that you have the latest burning software compatible with your unit. If you are using older version of the burning software like Nero or PowerDVD, you need to uninstall the old version, re-start your PC and install the new software that came with your DVD burner. DVD burning is not possible using file explorer.
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
2helpful
2answers
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
What type of disks does my TS L632D burn? +- ,CD, DVD Can't get CD's to burn?
go to my computer and look at the cd drive.if it says cd-rom you can't burn cds,dvd-rom will not burn dvds.only cd-rw,dvd-ram,dvd/cd-rw can burn cds.dvd-+,dvd-minus and dvd ram can burn dvds
1helpful
Would like to upgrade Dell Inspiron 1300 c.d drive
Is your dvd rom drive a RW drive? if not, you need to buy a RW-dvd rom drive to be able to RW dvds or cds.
If you already have a RW DVD Rom drive, you need to have a burning application (ex. nero burning rom). You can check on the internet and download a freeware and install it on your machine.
2answers
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
2answers
CD-RW/DVD ROM Combo
no you want a dvdrw or dvd burner
combo only burns cd's and reads dvd's(not write/burn)
2helpful
Acer Aspire 3000 DVD/CD-RW drive
If its the DVD/RW CD/RW unit it will possibly have...
NTI CD/DVD Burner which is a part of the Arcade System .
Easy to use and stable as anything I have seen before,3
Fast n Friendly,Remembering the max ram is 2GB and
with all barrells loaded performs like a beautiful piece of art.
Also Nero is an old favourite too.
Producing your own dvds from scratch is a satifying excercise and amazing when you can see the look in everyones eyes,,,,
Yes - Impact is everything.
I found your answer,
Grab you machine and look at the symbols on the disk draw.
The device you have is a CD/RW-DVD Rom.
What this means it is a CD Writer and a DVD Reader.
This device will never burn DVDs.sorry
To write DVDs you will need to buy DVD/RW device.
I hope this helps ,please rate me thanks
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
2answers
Toshiba SD R2132 CD-RW/DVD ROM
Your CD "Burn" laser or "Quadrant Detector" has "Faulted" a very common occurrence for these "Combo" drives,...So..I'm sorry but ya gonna haveta get another... as these ya can't fix. :(
Grand Canyon Tech
Grand Canyon Tech
