You need to change the t&p valve (temperature and pressure) most of the time this will solve the problem.
have you checked the water pressure?
have you checked the temperature of the water?
more than likely it is just the valve, these are common and can be picked up in any hardware store. be sure to check yours. there are 2 different models, one for a regular water heater, and one for a water heater with 2 inch foam. this one has a little longer stem, but will also work with the regular heater.
