SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
SOURCE: set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
By default, three options are enabled:
option #1: leave a message
options #5: call the operator
option #6: return to top menu
Here are some other features you may need
SOURCE: set number of rings
First press the menu button then scroll up or down to "initial setting" and press the select button. then select the set answering option then select the number of rings option now you can select the number of rings by scrolling up ^ or down. or you could just press the number on the keypad. Once you have selected the amount of rings you want press SAVE, then press off and your all set.
model kx-tga710e cordless phone.cannot answer calls.reciever button not registering.flashing emblem like a signal motif left hand bottom of display screen. it rings but can't answer as the reciever isn't accepting..can you help please
