I've had the same issue with a samsung. It had something to do with the PC not being able to detect the hardware when it came out of standby, and sending the wrong screen resolution to the TV. I ended up finally turning off standby on the PC (control panel-->power options) and just setting a screen saver.
Sometimes when the pc came back up, I could switch the source on the TV (to maybe an HDMI) then switch it back to the PC connector and it would find it. But, on mine it was inconsistent.
SOURCE: Display Ok in Safe Mode no display in normal
Run vga driver here. Last one on the bottom of the page.
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Driver&MenuID=7&LanID=9
SOURCE: Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Startup & Restart Problems on Athlon XP3000+/Abit KD7-G/WinXP
I believe your hard drive is dying. Buy another and get backup software like image home or reload everything from the install disks..
