Question about Emerson Televison & Video
How do I connect Emerson 19" model LC195EMX to direct TV
Model lc195emx serial ds1a0925181012
Clive Christie
    New Friend:
  • 26 Answers
USE THE HDMI PORT WITH A HDMI CABLE FROM THE REAR OF THE DIRECT TV BOX TO HDMI PORT ON TV SET THE ON YOUR REMOTE PRESS MENU SCROLL TO THE APPROPRIATE HDMI NUMBER .OR USE VIDEO AUDIO CABLE FROM DIRECT TV BOX CONNECT TO AV CONNECTIONS ON TV SET AND DO THE SAME BY HITTING MENU SCROLL TO AV THAT SHOULD DO THE TRICK....GOOD LUCK
Posted on Nov 21, 2014
3 Related Answers
Anonymous
  • 217 Answers
SOURCE: need remote code for emerson LC195emx LCD TV
hi! i have here a couple of codes for your emerson tv. you could try them 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037 hope it would work! goodluck!
Posted on Jun 03, 2010
caroldon
  • 17130 Answers
SOURCE: I have an Emerson HD digital TV model LC195EMX,
The indication of the standby light shows that the sub power circuit is functioning alright. Now on depressing the switch on power if there is no reaction then the main processor is getting an errror message for no switching. If you are getting any click and shut off then there is a power short/ fault in the HT circuit which requires further probe. You can check the main fuses and for dry soldering joints/ loose connectors in the main PCB, if all this is fine, I suggest you get help but ask your technician to give you an insight if the fault is in the control, main power (SMPS) or the HT. I hope this adivce helps. Good day.
Posted on Jul 07, 2010
Anonymous
  • 374 Answers
SOURCE: What is the digital remote
Ok, what kind of universal remote do you have?? With this model there are several that work. Emerson has a lot of codes so you need to go through them and see what works well with you.
Sorry for the long list but there are always more than one that works. Some Universal remotes also let you use more features with some codes so you may want to try a few and see what works well with you
Emerson 3 digit remote codes:004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Emerson 4 digitl remote codes:0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Please let me know if you need help of what kind of remote you are using and I can try to narrow it down.
Thanks again
Posted on Sep 10, 2010
Codigos de control ucr 3220 para tv LC195EMX
0478,0431,0449,0461. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Codigos de directv para tv emerson LC195EMX
0035,0033,0031,0039. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
1helpful
Can I records from a LC195EMX TV
No you can't output the video signal from the LC195EMX's tuner to another device. It only has video inputs to obtain the signal from a DVD or Blu-ray player, for example. There are audio outputs to use with a sound system or headphones. Thus you could record the audio track, if you desired.
The manual for the LC195EMX is available from Emerson: http://www.emersonaudiovideo.com/support/download_tv.php?id=6 . You will need some sort of a set top box to record to a DVD/VCR recorder with either an analog tuner or no tuner. (OTA digital to analog converters connect easily to DVD recorders. For best signal, use a switch to feed the signal to the recorder, instead the TV. Splitters can be used to feed both at the same time. However, the signal loss could make either or both devices unwatchable with the digital OTA signal. Amplified splitters can reduce this issue; however, I've had the amplifier fail on several occasions. Then the amplifier blocks all of the signal or blocks select channel frequencies.)
I hope this helps.
1helpful
How do i change screen modew without the remote on an emerson LC195EMX
Hello
It is very sorry to say that no universal remote controls are fully compactable with all the function to this set. You must have its original remote control to set all the functions. The original remote control to this set can be bought from the authorised service center for Emerson at your town. Its model number is (NH000UD). If you can get this model remote from anywhere other that service center, ie, form any local electronic sparepart selling shops, it's OK. Insist on the same model number. It is so important. Normally, remote control is an attached accessory with this set. OK.
Emerson LC195EMX I need the remote code to put for Direct TV
try 11864! it wasn't listed as one of the code options that they provided, but I saw someone say it worked for their tv & it actually worked! hope it works for you!
3helpful
NOT SURE OF THE TYPE OF TV ITS A EMERSON HD
maybe theres a defect in your tv. maybe theres a shorted parts in the board. you need a qualified technician to fix your problem.
5helpful
2answers
Need remote code for emerson LC195emx LCD TV to program my uverse remote. ATT codes don't work. Thanks
2helpful
Televison & Video Logo
Top Emerson Televison & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
