You will need to replace the rear drum bearing,a fairly common concern on these models. you should also inspect the front bearing surface the drum rides on for wear since replacement of the rear bearing requires removal of the drum anyway, when ordering the rear bearing kit make sure it comes with the special high temp grease that is used on the rear bearing. Good Luck
