Please provide more detail about your problem.
Does the screen play back the pictures ok but not during record mode? Or is it off all the time and you used a computer to review the shots that were taken?
Check the basics listed below:
1. The screen may be switched off.
Press the display button on the back while the camera is on.
This toggles the display setting between various settings such as
Off/ On / Info. Keep pressing the button to try the aternate modes, it just goes round and round to 2 -3 different modes.
2, Check that the monitor brightness setting is set to medium at least
in the menu's.
3. If the problem is only affecting recording then check that
the main record settings are correct for the type of scene you are taking. For
example don't use Beach, Snow, Candle or manual with a high shutter speed while taking regular daylight shots with minimal lighting.
. 4. If the LCD display has a hardware issue you could connect the camera
to a TV using the video output jack and look at it that way. Then
you'll know if the built-in LCD is ok or not.
5. Having a
damaged or stuck video output jack COULD cause this problem also since
that circuitry is designed to automatically shut off the built-in LCD
display when you connect a video cord to it. Note that having a video cable plugged
in to the video output jack would shut off the display also. Such as when you have it connected to a TV.
