Koss PC36 Cassette/CD Boombox Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my ac adapter abd need a new one. Where can I get one for my Koss pc36?
Anonymous
Level 3:
President:
  • Master 532 Answers
  • Posted on Aug 05, 2010
Anonymous
Master
Level 3:
President:
Answers
532
Questions
0
Helped
140054
Points
1388
Hi
The ac adapter is a common adapter which you can get at any electrical sop close to you.
Although, i don't no where you live but i believe you will get it in the nearest electrical shop.
Thanks for contacting FixYa
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
I have koss HD30 2pc. Amplified speakers and I need an AC wall adapter for them. What is the proper adapter for these?
If i remember correct should be between 6V to 9V at 800mA or 1A...if you plug the higher value adapter does not harm your speakers anyway, hope this helps...
I need a power cord for a midland wr100
Go to goodwill industries store,they all have them
1helpful
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
Lost my ac dc adapter need new one for rca small wonder camcorder
You can try www.ebay.com. I found the following AC adapter for the RCA Small Wonder camcorder:
http://cgi.ebay.com/RCA-EZ209HD-Small-Wonder-camera-CHARGER-AC-ADAPTER-/140516900106?pt=Batteries_Chargers&hash=item20b775bd0a#ht_1469wt_723
Mar 01, 2011 • Cameras
3helpful
3answers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
2helpful
One for all remote urc-3220 to koss dvd player ks-4110
i need the code to program my koss player on the one for all replacement urc 4220 remote
Top Koss Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ADMIN Eric
ADMIN Eric
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
