First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Hook up the 12v red on the parrot kit to the red/black on the iso connector.
The black goes to the brown on the iso.
The orange goes to the red/brown wire located in the middle of the previous wires.
That should be the power sorted out for you.
The tricky bit is the mute which I am currently working on, you can either cut off the black box and connect the red wire and blue wire to a speaker with the black connected to the mute wire. Or you could buy the correct iso adapter for around
