If you have Win 98/ME you can try downloading and registering the DLL, this solution usually does not work on 2000/xp/Vista, and may also not work on 98 (usually works fine on Win 95).
Here is how to for first method.
Here comes the second solution , that if done properly works.
You will probably need to make a backup of all your data for example using an external hard disk drive.
I suggest also taking a screenshot of installed hardware from control panel/system, or writing details for sound card, video card, modem and network card (if any).
Then reinstall Windows as new installation, using either Windows setup disk or the set of recovery disks provided with computer (if any).
After this you will have to reinstall all drivers and software for your PC.
Here is how to for second solution
Here is complete tutorial
Regards
Hi harold what operating system do you have?
it seems that a reinstall is probably the best , hope you have your data on a seperate partition or hard disk, and recent backups?
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
