List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
This happened to me three times with a brand new oven, they kept coming back and replacing the fuse. I finally made the Kitchenaid dealer replace the whole oven, never happened again.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Unplug
your oven. Insert the size 15 Security Torx bit into your
multi-bit screwdriver and remove the screws from the back panel. Take
off the back panel.
Locate
the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end.
Carefully remove the fuse. Avoid touching the transformer or other
parts inside the oven.
Purchase
a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse.
Consult your owner's manual to find out what kind of fuse is used, or
take the old fuse into the store to find the exact match.
Replace
the fuse. Put the cover back on and see if your oven works. If it
does, replace the screws. If it does not, try a different fuse. If the
oven still does not turn on, you may have to have it replaced of
professionally repaired.
Unplug
off the back panel.
2 Locate
Purchase
Replace
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
sensor or oven temperature sensor fuse opened
Replace oven
temperature sensor or fuse
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models 2. Test relay contact operation 3. High resistance in oven temperature sensor
F3
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
