Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Anonymous Posted on Aug 02, 2010
We have a LM the professional line, 81 LM 1/2 hp opener. We just had a professional change the coils and 2 days later the remotes (both) and the keypad stopped working altogether. We have changed the batteries and codes trying to troublshoot - that did not help. The hardwired button still works. any ideas?
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Aug 02, 2010
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1458840
Points
8183
The receiver portion of your logic board has quit.
Testimonial: "Thanks so much for the info. I'll see if I can replace the piece. Again Thanks"
I have a lift master 1250 lm the remotes dont work and I have no green lights on door sensors ,but I have 6.2 volts dc to each. What might be the problem.
Are the sensors lined up? They will get voltage without being aligned. Batteries good? Try opening the door by the button on wall or touch the contacts on back of motor with something conductive to act like the remote and see if it opens. This will tell you either remote or sensor issue or the opener itself
2answers
I have a lm-1079 remote and i need the program codes for a Panasonic. Tv/ dvd/vhs combo can you help with instructions on how to program the codes to the remote..... Thank you
How do I program a GE LM 1079 - ManualsOnline.com
tv.manualsonline.com/...remote...remote/how-do-i-program-a-ge-lm-107...
Aug 24, 2014 - Question About Universal Remote Control Universal Remote LM 1079. How do I program a GE LM 1079... How do I ... Get the Manual Here.
Universal Remote Control Product Support ' Manuals
I have a broksonic TV. and I need the code to a lm-1079 TV remote
Universal Remote Control Universal Remote lm-1079 Need ...
tv.manualsonline.com/...remote-control/...remote/need-codes-for-univers...
May 9, 2014 - Need codes for universal remote model number lm-1079. Asked by paula young on ... 1 how to set code for tv from lm_1079. Was this answer ...Missing: broksonic
Universal Remote Control Product Support ' ManualsOnline ...
tv.manualsonline.com/support/universal-remote-control/
Need codes for universal remote model number lm-10. Universal Remote ... UniversalRemote Control Universal Remote ECCO LCD 24?€? Tv. 0 Solutions ...
Universal Remote Control Codes - iWave Super-Sized
If i set air at 76 come home later in evening its at 81+whats wrong?
lots of reasons,,, indoor coils dirty,,, outdoor coils dirty,,,, fan motor bad,,, outdoor fan motor bad,,, low on freon, filter needs to be changed
1helpful
Zenith hotel TV turns itself on
Most of the Hotel sets use a different remote to enter the hidden menus--the system that set uses was likely on channel 81 and where it was used they needed it to come on at a specific time----going to get that specific service remote and info on how to change settings---this is the issue with buying these commercial sets.
Zenith is part of LG but different phone numbers etc
Product Lift Master Professional Line 1/2 HP Security + Model # 1265LM Door goes down intermittently. Door will go down approx. 8 - 10 inches, stop and then retract. Remote in hand, I press the...
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
Access system for 3/4 hp belt drive works sometimes, however with change in temp, climate conditions, the system does not work at all. a few days later the system will work without any adjustments
Some electronic components become sensitive to temperature changes and will quit working. If you have more than one remote unit and the problem exists with them all then your logic board is bad.
2answers
Remote will not take code
If you just bought this remote you may have the wrong one for your unit.
2helpful
2answers
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
