20 Most Recent Ruud UAKA060 Air Conditioner Questions & Answers
Sometimes, when the inside blower shuts down, the
I was leaning towards a bad contactor. Either sticking sometimes or not making good contact. I would inspect the contactor for pits or burn marks near the contacts. DO SO WITH POWER OFF of course...but, what's the reset button you are referring to?? I'm assuming this is a heat pump, please send model number!! If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
7/6/2017 10:57:32 PM • Ruud UAKA060 Air... • Answered on Jul 06, 2017
Uaka
it is a 5 ton by your model number.
8/17/2015 4:43:39 PM • Ruud UAKA060 Air... • Answered on Aug 17, 2015
I need to install a thermostat to a ruud
Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g.
12/11/2014 10:56:38 PM • Ruud UAKA060 Air... • Answered on Dec 11, 2014
If i set air at 76 come home later in evening its at 81+whats wrong?
lots of reasons,,, indoor coils dirty,,, outdoor coils dirty,,,, fan motor bad,,, outdoor fan motor bad,,, low on freon, filter needs to be changed
9/1/2014 1:48:45 AM • Ruud UAKA060 Air... • Answered on Sep 01, 2014
2answers
The thermostat has a timer on the on- cycle (5 min delay for the outside unit and blower inside) if you are not gonna call a service guy then ( for $25) you can go to homedepot (whatever you got out there) and buy a honeywell vertical digital heat and ac t'stat.
this one doesnt require you to set it up for a particular application. this may solve your problem. but as for warm air out of the registers you need a service guy to check that
7/4/2014 12:39:18 AM • Ruud UAKA060 Air... • Answered on Jul 04, 2014
What ton is a ruud uaka-060jaz
This is a 5 ton unit. There is 12,000 btu's per ton, so you would multiply 12,000 x 5 = 60,000 btu's.
5/17/2014 11:10:54 PM • Ruud UAKA060 Air... • Answered on May 17, 2014
The furnace is running but there is no cool air.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
10/20/2013 2:36:37 AM • Ruud UAKA060 Air... • Answered on Oct 20, 2013
AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
7/8/2013 1:09:01 AM • Ruud UAKA060 Air... • Answered on Jul 08, 2013
2answers
An came on by itself and won't cut off
If your indoor unit is electric and not gas or oil, then your problem is either in the control wiring or a relay. With your circuit breaker OFF: Start by removing the wire on "G" at your control board. If you have an older model, there might be a wire nut connection for your thermostat wires.......disconnect the wire nut with the green wire which is the most commonly colored wire used to control the fan. Tape off the end of the wire to prevent it from shorting......turn the breaker on. If the blower continues to run, you have a problem with a relay. If the unit is heating while the fan is running, you most likely have a stuck heating sequencer. If there is no heat, you most likely have a stuck fan relay.
Here is a video to help you identify heat relays/sequencers and fan relays. Having a stuck fan/blower relay is a fairly common problem. Often, you can gently tap the relay to "free" it and stop the fan. However, once they start "sticking", they will continue to do so.
I hope you find this information to be very helpful to you, moving forward. :-)
11/22/2011 3:52:34 AM • Ruud UAKA060 Air... • Answered on Nov 22, 2011
11 year old model that will not shut off. Bang on
It sounds like one of the start or run relays are jamming. Have a look for them , usually 1 or 2 where the electrical box is. The relays may have a clear covering over them. if it looks burnt or discolored , then thats the failed one. It is possible it may also be the contactor sticking which is a larger box with wires going in at the top and bottom. Usually, there is a button in the middle which pulls in when the compressor starts and pops out when turned off. The smaller relays, usually only control the fans. You will need to determine, is it the fans not turning off or is it the compressor??
9/9/2011 5:18:46 PM • Ruud UAKA060 Air... • Answered on Sep 09, 2011
Unit needs a new capacitor and it does not the
Short of going direct to the manufacturer and getting the genuine part off them using the model number, it would be very difficult. Compressor size and machine size very often have no bearing on what capacitance the capacitor has... Have a very close look at the capacitor for a uf rating.. this is the value you need. sometimes, it is listed on the wiring diagram which is usually behind the panel which covers the main wiring terminal box on the outdoor unit.
8/4/2011 3:30:54 PM • Ruud UAKA060 Air... • Answered on Aug 04, 2011
0answers
What is the rated run amperage on this condenser
it is a five ton condensor, ratings will be on lable. Under RLA this stands for running load amps. hope this helps.
7/7/2011 10:54:14 AM • Ruud UAKA060 Air... • Answered on Jul 07, 2011
2answers
Line 2 fuse is bad. How do I fix it? What type of
the fuses should be time delay 30 amp both fuses should be the same
8/21/2010 4:50:37 AM • Ruud UAKA060 Air... • Answered on Aug 21, 2010
Can you tell me where the drain valve is located
The only standard location of the drain line is at the point of origination.....which is the Air Handling Unit. Air Handling Units are typically installed in the Garage, Under the House, in a Closet, or in the Attic. You will have to locate the drain at the Air Handler and follow it to the end. Typically, the end of the drain will be somewhere near your condensing unit. In time, they can get broken off or buried which could make them very difficult to locate. In rare instances, I have seen them terminate into a sewage vent line (NOT recommended and against code in most places). They could terminate just about anywhere; hence, why the best thing to do is to find it at the air handler and follow it to where it leaves your house.
Without being on-site, toolbox in hand, I hope you find this helpful. :-)
4/15/2010 5:23:03 AM • Ruud UAKA060 Air... • Answered on Apr 15, 2010
A/C heater not working
Check the limit switch next to the leads to the heating element ohm ot out or jump it to see if that is where the power is stopping.
3/10/2010 7:44:57 PM • Ruud UAKA060 Air... • Answered on Mar 10, 2010
Largest circut breaker allowed on a residential heat pump
Sounds like the breaker is doing it's job. Stopping an over amping condition. You need to find out what the breaker is feeding power to. If it is the outdoor unit or the indoor unit. Also, the wire used has to be sized to the breaker otherwise, it will burn inside the walls and start a fire! Both the indoor and outdoor units should have tags or lables stating what the required amount of power is required. Better not let them do anything else untill you get more info. Sounds very dangerous to me but, I'm not there seeing what's going on.
Hope this helps!
2/6/2010 9:24:41 PM • Ruud UAKA060 Air... • Answered on Feb 06, 2010
2answers
I get 0 pressure on the suction line and about 160 on the high.
Bad thermostaic expansion valve inside.
1/22/2010 6:13:59 PM • Ruud UAKA060 Air... • Answered on Jan 22, 2010
Air conditioner shuts off early.
Hi, thermostats is not problem , it's asking for cooling when it should, it's your condensing unit outside, if mechanics said, system is o/k. then it's location of condensing unit, check location of your condensing unit, in relation to direct sunlight, condensing unit best location is always a cool place, preferable away from direct sunlight, check to see, when unit is doing that, if it's expose to direct sunlight, that could be your problem, direct sunlight for long periods could cause the high pressure & temp. controls malfunction. or maybe system is not fully charge with freon, double check freon charge. if direct sunlight is your problem, build a shade or change location of condensing unit, good luck.
8/5/2009 4:17:17 AM • Ruud UAKA060 Air... • Answered on Aug 05, 2009
Ruud UAKA060 Air Conditioner Logo
31 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
tell me drain valve located
  • Heating & Cooling
