SOURCE: where is the serial number of my Canon Vixia HF200
I have Canon Vixia HF20 A and I when installing the Pixela Application that comes with it, I used the numbers under the battery. You'll need to concatenate all three numbers together as in my case for it to be correct... e.g 111122223333, 1s represent line 1, 2s line 2 and 3s line 3.
SOURCE: I am looking for the serial number for the Canon
The serial number is located on the top surface of the battery compartment cover.
Refer to:
http://gdlp01.c-wss.com/gds/7/0300001917/01/fs20-21-22-200-nim-en.pdf
Go to Page 14.
Thanks for using Fixya.
Please take a moment to rate this solution. Thanks!
SOURCE: Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
