Garmin nuvi 1490T GPS Receiver Logo
Posted on Jul 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If I have a new nuvi 1490 pre loaded with Europe and i want to use another map how do I do it without overwriting the preloaded map?
Anonymous
Level 3:
  • Master 1,514 Answers
  • Posted on Jul 29, 2010
Anonymous
Master
Level 3:
Answers
1514
Questions
Helped
332236
Points
3516
Go to www.garmin.com. If you haven't already registered your sat nav on the site you'll need to do so. You'll be asked to create a username and password. Write them down as you'll need them again. Once registered you'll be able to log in to My Garmin. Click on My Maps and you'll have an option to buy other maps. If there's not enough space for both maps you'll be able to select what you want.
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 • Garmin GPS
tip
Garmin Nuvi 1490 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1490 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________________
Garmin Nuvi 1490 Manual Download
Garmin Nuvi 1490 QuickStart Download
Garmin Nuvi 1490 Favorites Backup
Garmin Nuvi 1490 Hard Reset
on May 27, 2010 • GPS
tip
Garmin Nuvi 1490 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
I want t travel accross europe and do not have full addresses to enter into my garmin nuvi 250 please could you tell me how to do this Lynn
The nuvi 270 is the model that comes with pre-loaded maps of europe. The nuvi 250 only has North America. You can find the right maps on Garmin at: https://buy.garmin.com/shop/buymaps.do
You can purchase all of europe or select areas which are $50 dollars cheaper.
Jan 20, 2009 • GPS
2answers
Going to Mexico and my garmin will not display it.
There are a variety of Garmin® GPS devices that come preloaded with mapping not just for the United States but also for Europe and Mexico. Any nuvi® that has 70 in the model number will have preloaded mapping for North America and Europe.
Example: nuvi 270, nuvi 370, nuvi 670, nuvi 770
Also, some specialty models will have preloaded mapping for North America and Mexico. These units include the nuvi 200 Mexico (p/n 010-00621-2A) and the Nuvi 260W Mexico (p/n 010-00656-37).
To obtain Mexico maps, go to this link:
http://www8.garmin.com/cartography/mapSource/citynavntmexico.jsp#price
Oct 11, 2008 • Garmin GPS
2answers
Tomtom730GPS
The 730, unlike the 930, doesn't come with European maps preloaded. You can find the most up to date Tele Atlas maps of the UK & Europe over at TomTom's Map Store.
1helpful
Europe SD card wont work
tap on the wrench, tap on map, tap on about map, there you should see the base map checked, and the Europe map unchecked, uncheck the us map and check the europe map by tapping on the check box. leave the menu.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
