Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
Posted on Jul 29, 2010
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Aug 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4253
Points
37
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
I have a Zanussi Spaceplus Orange light has come on this morning?
Got a zanuzzoe Electrolux. Aqua cycle filter button is orange won't reset
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
My Zanussi DE 4544s dishwasher has this fault, when you put any cycle on it reverts to the flashing green lights......any help would be much appreciated.
You need to go on line to the Zanussi web site and request the error codes for this machine. Once you know what the problem is you can pose a question!
Dec 31, 2012 • Dishwashers
Aqua pulse mains light ok but does not run ?
You probably have either a bad powercord, motor or control panel.
1helpful
Loud banging in spin cycle zanussi aqua cycle
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
Zanussi Dishwasher Model no DE6744 Not working
HI. After me fiddling about with the machine,checkingto make sure water was available to it and trying to locate the float switch (whicu i didnt) .
Then i left it standing overnight aqnd the believe it or not it worked in the morning.
I let it run through the cycles of a program which it did ok.
Hoping it carries on ok. Kenethyorky
Aug 11, 2008 • Dishwashers
2answers
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Zanussi DE6755
This is for the right model, but is the UK version, all should be the same but power supply details might differ if you are in US etc. http://www.serviceforce.co.uk/pdfs/U23297.pdf Hope this helps :)
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
