Samsung 710m sync master not optimum mode recomended mode 1280 x 1024 60Hz
SOURCE: Samsung LCD 510N Monitor not optimum mode error
Paiarunk, OK, I was having a mental block for a bit. Your PC will only boot into VGA Mode, I?m assuming if you don?t Windows will crash or something. Exactly what led up to this, have you added a new video card or loaded new drivers? What operating system are you using? Let me know the answers to these questions and any other pertinent information and we?ll start working on this.
SOURCE: how to reset factory settings of samsung sync master710v
Disconnect de power Cord behind the monitor for about 10 minutes. Then reconnect again. If the problem persist you can call the Samsung and talk about your problem. I had the same problem they swap my monitor, because was a fault (if your monitor still in the warranty.
SOURCE: samsun 710v not optimum mode problem
This is a common issue with all samsung moitors al models i have dozens with the same issue
SOURCE: My screen is showing message
you need to change your video adapter resolution to this one,if you can`t see nothing in normal moe login in safe mode(tap f8 on boot)and change resolution then restart
