IBM Magstar 3590 Magstar Tape Drive Logo
raj jha Posted on Jul 19, 2010
Connecting tape drive in series
Can i connect 4 tape drice in series if yes than how???
Acer red light battery
1) http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Yes, I know. Aspire 5100 series of Notebook PC, not the Aspire 5230 series. I am looking at the Service Manual for the Aspire 5230 series right now, and the above link is a good basic pictorial guide.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the subheading - Aspire 1200. (1200 in Blue)
Go down to the 6th line, scroll across, and left-click on 5230 in blue.
(Takes few seconds before the first page comes up.
In the PDF file page number box at the top, go to Page 119)
2) If you mess up with the connection of the LCD Panel Cable, to the LCD Panel, (On back), your laptop will not power up.
Those tiny contact pins on that cable's connector, must line up exactly, and be plugged in tightly to the LCD Panel.
Not plugged in tightly? You won't see it visually. You have to physically check.
Also use the old tape that was there, to tape over the connector once installed, on the back of the LCD Panel.
Ripped it all the way off? Oops! Use some new tape. (Not duct tape, scotch tape, or medical tape. Box tape with strands in it)
3) Connector of LCD Panel Cable, connected tightly into motherboard?
4) Screen Inverter wires connected? Connectors are keyed differently from each other, BUT, are they connected correctly?
5) Why was the LCD Panel replaced? Damaged? Did the LCD Panel Cable receive damage? Did you perform a cursory visual inspection of it's sheath, at least? Sheath showed ANY damage, did you perform a continuity check of each wire in the cable, with a multimeter set to Ohm's? (LCD Panel Cable unplugged from motherboard, and LCD Panel, of course)
6) If there was damage, did the screen Inverter receive damage?
7) Connect the LCD Panel Cable's ground wire/s back to THE ground screw/s? Good bright clean connection area for those eyelet ground terminal/s?
8) Did you crossover the new LCD Panel to the old LCD Panel, to make sure it is a direct replacement?
NOTE*
A screen Inverter, and an LCD screen, (LCD Panel for Acer), are a MATCHED unit.
9) AC adapter plugged into power, and plugged into laptop, along with the battery?
Post back in a Comment, and if none of the above is the problem, we'll go on from there.
Regards,
joecoolvette
3answers
WHAT IS SATA?
Sata is a serial based interface that alowes hard drives and cd/dvd drice to communicate with the motherboard. General is a Red cable with black connectors.
My WD2500XMS passport drice is powering up when connected by the USB cable, but it is not being recognized as an external drive and I am unable to access it
Some of the External drives comes with installation disc. before it can be recognize you have to download the driver at :
http://support.wdc.com/product/download.asp?modelno=WD2500XMS&x=5&y=14
The website only if you don't have the installation disc that came with the product.
Hope this solution works for you.
Hello, I have several DTF2 tapes that I would like to extract the files from. is it possible to hookup a DTF drive to a pc workstation and be able to see and extract the files? thanks raf
Yes, you will need a fiber channel host bus adapter (HBA) in the PC. Install the HBA in the PC and connect it to your fabric, and then zone it the same as you would zone a server.
If you don't have a fiber channel fabric, it might work if you connect the HBA directly to the tape drive, but you definitely will need a HBA.
Hi Experts Can I connect External Harddisk to LCD Samsung Series 4 ? Thanks
yes you can connect but it will keep disconnecting,but if your lucky it wont,maybe its about compatability of the tv and the hardrive,but the led design samsung series 4 it does.
I have a Bose 901 Series VI speaker system & have recently purchased a Pioneer VSX-1020-K AV Receiver. How do I connect the 901's EQ to this amp. I believe the only option is the CDR/TAPE IN/OUT...
This receiver has no pre-amp outs to drive the required separate amp the 901's need for you to continue to have multichannel digital audio. The reason: activation of a tape loop disables digital inputs. But they DID give you Front Height. Oh boy.
My 16 gb cruzer thumb drive lost data and says 0 info on the drice, won't reformat od show/do anything can it be recovered or fixed?
There are 2 support links for checking the Cruzer's connection status:
  • The Device Manager check
Flash drive could not be detected by the computer:
http://kb.sandisk.com/app/answers/detail/a_id/10
  • The Disk Management check
Flash drive could not be detected due to "drive letter conflict":
http://kb.sandisk.com/app/answers/detail/a_id/76
When more help is needed just post a comment.
1helpful
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=2777&name=Hard-Drive-Enclosure
Hope that helps.........
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
