the reason why is because ,hp computers use a different set of video drivers than does win/microsoft, when upgrading to xp you must install xp 1st release no svc pacs, then must have the hp video drivers oem for the model you are installing xp to , they can be downloaded on hp driver download, or the intel driver download site, unless you have a different chip set, the oem drivers must also be puton either a floppy disk or cd , that is made bootable from restart, make shure either the A drive or the C drive is set to boot before the hard drive so it will pick up the bootable disk you made with the downloaded drivers , then reboot the computer with the xp disk , at the disk partion screen select leave old files intact with the new install !
Power
on computer and enter the set up (BIOS) menu by tapping the F2 key. Hold down
the <Alt> key and depress the <E> then the <F> keys in
succession. This will force the motherboard to load default settings and also
force the motherboard to redetect all IDE devices. Note: The selection for the
floppy drive will be set to ON. If you do not have one then you must disable
floppy in set up (BIOS) menu.
You need to press F6 and load special drivers for your disk driver card See which disk adapter your server has and get the drivers on a floppy disk Put the disk into your computer before seutp, then click F6 when prompted it will search your floppy drive for them
Your computer cannot boot up because it cannot find a boot up program from any of your boot devices.
This fault could be caused by a faulty hard disk or you have a non-boot floppy disk in the floppy drive. In this case remove the floppy disk and boot up your computer again.
If the hard disk is faulty, replace the hard drive and install Windows on the new hard drive, plus the computer's device drivers and your programs to get the computer operating again.
the recovery disk is designed to repair or restore a system to its previous factory condition and is not a full installation. the formating of your hdd would have erased all the data required for this process to be completed. you can try a recovery utility that may be able to help you at this link. the disk might not have been saved in an .iso format to tell the computer to run it before starting an OS. if this disk is recognized and runs on your system then you will need to attempt a recovery, which is unlikely since the drive has allready been formated many necessary system files may not be able to be restored. at this point a complete new install will be necessary.
Good Luck!
Your new hard drive has a name, like Seagate, Western Digtail, bla, bla... Go to the Mfg's web site for your drive. Download the bootable floppy disk manager setup utilities. If you have a floppy disk drive. If you don't have a floppy drive most Mfg's allow you to make a bootable CD. Lastly or maybe I should have mentioned this first. Make sure your drive is pinned out correctly. I'm only guessing you bought an IDE drive which has a jumper for setting the drive as a master or a slave or a master with a slave.
Hi Elia,
Could be a couple of things:
-Your drive may only be a 720K drive. They will format 1.44 MB disks but only with a 720K format. The test is inserting a HD disk and try formatting it as HD.
-The disk could be mislabeled, HD disks have two holes on end opposite the slide, one to write protect the disk and the other to signal to 720/1.44 capable drives this is a HD disk.
-The HD disk could be formatted as a 720K disk even though it is an HD disk, reformat as HD.
-The new, used drive could be damaged.
-The drive could be configured as a 720K by the computers BIOS. You?ll have to enter the BIOS setup find the config for the A drive and set to 1.44MB.
Let us know what happens and please don?t forget to rate the posting.
