20 Most Recent HP Compaq nx8220 Notebook Questions & Answers
one way is to remove the coms battery for a couple of mins then put it back,not saying it will work but worth a try.
HP Compaq nx8220... | Answered on Apr 14, 2015
one way is to take out the cmos battery for a couple of mins then put it back,not saying it will work but worth a try.
Thanks for letting us know :P. Next time posting a question please provide details.
HP Compaq nx8220... | Answered on Nov 11, 2013
download from manufacturer supplier go www8.hp.com
and uninstall the old one corrupted, and install the new ones and ready.
God bless you
HP Compaq nx8220... | Answered on Jul 11, 2013
Reinstall windows. Before that use Hiren CD and check memory and hdd.
HP Compaq nx8220... | Answered on Apr 17, 2013
the reason why is because ,hp computers use a different set of video drivers than does win/microsoft, when upgrading to xp you must install xp 1st release no svc pacs, then must have the hp video drivers oem for the model you are installing xp to , they can be downloaded on hp driver download, or the intel driver download site, unless you have a different chip set, the oem drivers must also be puton either a floppy disk or cd , that is made bootable from restart, make shure either the A drive or the C drive is set to boot before the hard drive so it will pick up the bootable disk you made with the downloaded drivers , then reboot the computer with the xp disk , at the disk partion screen select leave old files intact with the new install !
HP Compaq nx8220... | Answered on Jan 28, 2013
Hi there, if you have the recovery disc try that first. However, I had to deal with a similar problem on a FUJITSU LIFEBOOK, and after trying many possible solutions it turned out to be - hard disk failure, sorry. Hope this is not the case for you.
HP Compaq nx8220... | Answered on Jan 22, 2013
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
HP Compaq nx8220... | Answered on Nov 23, 2012
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
HP Compaq nx8220... | Answered on Jun 28, 2012
Your rtc battery (also called the cmos battery) Needs to be replaced.
HP Compaq nx8220... | Answered on Jun 27, 2012
HP Compaq nx8220 Notebook Logo
80 questions posted
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
problem hp laserjet 4100n offline mode
  • Computers & Internet
