If lense is cracked this can occur from water or rain on a hot bulb. this can also occur from oils on your hands when replacing bulb. Make sure you don't touch bulb when replacing. If bulb is touched wipe it off with tissue or a towel. If non of this is an issue check to make sure that the correct type fuse is in place, and make sure voltage at head lamp is not too high. Also check for ground problems.
