I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
