Hello Marionria,
First check that the disc is OK and there are no scratches, etc. If there are, you could use a bit of toothpaste and a clean cloth to get rid of the scratches. Just use a bit of paste on the cloth and wipe the CD in circular motions. Now use a clean part of the cloth and wipe away the toothpaste. Try the CD now and see if it works.
If that doesn't work, try doing a clean install. It could be that there are other software conflicting with the install. Procedure as follows (I am assuming you have XP):
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
8. Install the game CD.
After performing the necessary steps, restore your system by doing the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2 .Replace checkmarks in the items from which you previously removed.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, this should work. If not, it could be that you have a corrupt CD. If this is the case, try to get it replaced from the point of purchase.
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
If you are using a different OS than XP, please post back the OS that you have and I will send the appropriate instructions for that Operating System (OS).
Cheers!
IrishDruid
Have you been able to resolve your problem? If you have,
please close this problem ticket with a Helpful or FixYa! rating. I would be
very grateful for your gesture of appreciation.
post them here.
Cheers!
IrishDruid
"Discover
How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
If you find that the solution/answer I provided led you
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution. I would be very grateful for your show of appreciation.
post them here.
Cheers!
IrishDruid
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved."FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)"Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
