Cuisinart Brew Central 12-cup Coffee Maker Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power getting to the coffee maker
Tried various electrical outlets,none of guages are working including the clock
Anonymous
Level 3:
President:
  • Master 512 Answers
  • Posted on Jul 13, 2010
Anonymous
Master
Level 3:
President:
Answers
512
Questions
0
Helped
208126
Points
1697
You have a short in unit. Probably the on off button. But without taking apart and troubleshooting, hard to tell you which one. These have a 3 year warranty. Call cuisinart to see if yours is under warranty. 1-800-729-0190.
I have Mr. Coffee maker PSTX Series clock is blinking 12:00am tried pressing hour and minute button will not change time? What else do I need to do?
Pick the manual for your model from
Instruction Manuals at MrCoffee com
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-mr-coffee-Library/default/dw622cdce2/documents/instruction-manuals/BVMC-PSTX95GTF_43_57840520.PDF
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you reach the current time. The AM or PM indicator will light at the bottom of the display (Figure 1).
I have a Keurig coffee maker model 155, very nice machine. However, it will not power up and work after a power failure. Is there some special reset button on this machine, perhaps?
The Keurig coffee maker model 155 does not have a special reset button. However, there are a few things you can try to get the machine working again after a power outage:
  1. Check the power source: Make sure the coffee maker is properly plugged in and the outlet is working. You can try plugging in a different device to the outlet to ensure it is working properly.
  2. Check the circuit breaker: If the outlet is not working, check the circuit breaker to see if it has tripped. If so, reset the breaker and try plugging in the coffee maker again.
  3. Unplug and replug the machine: If the outlet is working properly, try unplugging the coffee maker from the power source for a few minutes and then plugging it back in. This can sometimes reset the machine and get it working again.
  4. Contact Keurig support: If none of the above solutions work, contact Keurig support for further assistance. They may be able to provide additional troubleshooting steps or help you determine if there is a larger issue with the machine that requires repair or replacement.
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
been set yet.
2.
The clock is now set!
NOTE:
Pressing any button before setting the clock will cause the
clock to start keeping time from 12:00 a.m. You must set the clock
if you want to use the Delay Brew feature.
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Why isn't my coffeemaker brewing coffee?
Plz try the following steps ..hope it serves ur purpose:
  1. Make sure the coffeemaker is plugged into a working 120V electrical outlet.
  2. Make sure the power switch is turned on.
  3. Make sure the water reservoir has water in it.
  4. The unit may require cleaning to remove mineral deposits that build up over time.
  5. If the coffeemaker is equipped with a clock and the clock is working properly but the unit will not brew, please contact the nearest Authorized Service Center.
Thanx
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
Coffee maker is about 2.5 years old. Has worked fine until...
does it have two switches? mine does and if the main is off, the other is off.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
