Question about Keurig K-Cup Keurig OfficePRO Premier Single-Cup Coffee Brewing System
I have a Keurig coffee maker model 155, very nice machine. However, it will not power up and work after a power failure. Is there some special reset button on this machine, perhaps?
I experienced a power failure recently, and the preview window went blank when power came back up. I unplugged the machine and plugged back in. It makes a click but will not power up. Can you explain this.
Posted by James on
I have a Keurig office pro coffee maker. After a power failure it will not work
Have you tried rebooting it like a computer? Unplug the cord and wait a bit then plug it back in? If that doesn't work the power spike of the outage likely damaged your computer board in the Keurig.
Aug 17, 2016 | Keurig Coffee Makers & Espresso Machines
Keurig special edition leaking water underneath
Reset and Descale with mix of soulutions Page 18 Manual.
May 15, 2012 | Keurig Special Edition B60 Coffee Maker
Maker has worked great for 9 months and went to use it today and no power. I tried three different outlets and they checked out OK with other appliances so not the power. Is there a way to reset. Not...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
May 29, 2011 | Keurig Special Edition B60 Coffee Maker
Keurig will not pull water into coffee maker
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 18, 2011 | Keurig Special Edition B60 Coffee Maker
Water does not flow up to fill cup . Keurig model b-40.power light comes on and nothing happens.
Probably failure of a poorly made Chinese thermal fuse.
Other owners of this brand have gotten replacement for other models; contact them directly.
Jan 24, 2011 | Keurig Elite B40 Coffee Maker
Keurig Special edition stopped brewing
heatman101
Dec 25, 2010 | Keurig Special Edition B60 Coffee Maker
PIt was plugged into a power strip w/a microwave. When the coffee maker was turned on at the same time the microwave was on and the power strip turned off both machines. Reset the power strip and the...
The Keurig has had an electrical failure inside, when it failed it tripped your power strip. Once the electrical fault in the Keurig has been fixed you will again be able to run both appliances from the power strip.
Dec 29, 2017 | Keurig B100 Coffee Maker
The keurig coffee maker seems to have a defect when pumping the water
heatman101
Oct 28, 2010 | Keurig Special Edition B60 Coffee Maker
Had a power failure in my house. I turned on but hours later still not able to brew. I have reset. Still not working. Says it is brewing but nothing comes out.
Unfortunately Keurig does not have any service centers around the country nor are parts available from them. You are going to have to send the machine into them directly to take care of the issue.
Sep 15, 2010 | Keurig Platinum B70 Coffee Maker
Keurig K-Cup Keurig OfficePRO Premier Single-Cup Coffee Brewing System Logo
2,126 people viewed this question
Top Keurig K-Cup Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Keurig K-Cup Wine and Spirit Expert? Answer questions, earn points and help others
