Cars & Trucks Logo
A
Anonymous Posted on Jun 28, 2010
I have a 1985 camaro berlinetta and im putting a new stereo system into it. i need to know if the darker color or the wire with a stripe on it is a negative or a positive...the speakers are connected differently than todays.
Anonymous
Level 3:
  • Chevrolet Master 1,940 Answers
  • Posted on Jul 13, 2010
Anonymous
Chevrolet Master
Level 3:
Answers
1940
Questions
0
Helped
954291
Points
5951
The stripe is probably the +, and the darker color wire is probably the -. If unsure, test it with a multimeter.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1999 Ford Taurus stereo wiring diagram
These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link
https://www.justanswer.com/ford/0hkix-find-1999-ford-taurus-stereo-wiring-harness-diagram.html
These are the other two websites.
1999 Ford Taurus Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
1999 Ford Taurus Stereo Wiring ; Ground, Black/Light Green ; Illumination, Light Blue/Red ; Dimmer, n/a ; Antenna, Left Rear ; Front Speakers, 5" x 7" Doors.
1999 Ford Taurus Radio Wiring Diagram
MODIFIEDLIFE https://www.modifiedlife.com > 1999-ford-taurus-radi...
Our 1999 Ford Taurus radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 1999 Ford Taurus Radio Wiring Diagram; 1999 ...
.. Here is the AM/FM Radio wiring
2answers
Stereo color codes for a 1997 Camaro z28
Hi John.
not sure if this will help you out.
or try this link might help you out.
https://www.google.com/search?client=avast-a-1&q=Stereo+color+codes+for+a+1997+Camero+z28&oq=Stereo+color+codes+for+a+1997+Camero+z28&aqs=avast..69i57.708j0j7&ie=UTF-8
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
I have a 1985 Camaro Berlinetta with a unknown 305 in it. The noise on the starter broke in half I took it out it's for a 1980 Impala. I tried a 1985 Camaro starter no luck. I put a new 1980 impala starter...
If I remember correctly, there were two noses for those starters, either should work as the difference was that on one both bolts were long, the other used a long and short one.
The one thing that may be missing there is that both starters used a front support bracket that either fastened to the case or to one long bolt that holds the starter together that had a short threaded extension on it. the other end of the bracket attaches to the engine block. Under load, that bracket keeps the starter from trying to tilt up and break.
Another thing that can break the nose is an ignition cross-fire. that can shock the housing and also give you that problem. Make sure the ignition wires are good as well as the cap and rotor.
Need picture or diagram for 1985 chevy camaro berlinetta 4 cylider engine
Go to eautorepair.net and for a small price you can get what you need for 8 days.
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
2answers
Im installing a new stereo and need a wireing digram
You'll need to determine which of these connectors match yours, then follow the appropriate diagrams:
Nissan Audio Wiring - 1985 to 1994:
Nissan Audio Wiring - 1995 onwards:
Let me know how you get on...
Cheers,
Scott
1helpful
85 camaro radio wire colors?
Here, review the GM Radio Wire & Color Code Information (page 7) and the GM Harnesses Wire Information
I really hope help you with this. Good luck (remember rated this help).
2answers
Stereo wireing
go to advanced auto parts and buy a connector for your car. just go and give them year, model and make and when you get it connect the same color wires from the stereo to the stereo harness. all of the colors are the same.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
