It can be many things that makes it go into protect. First check output transistors. Check R347/R348 on output L/R channels. Also a common problem are broken resistors on PSU (power supply unit) like R243, R245 & R248. Check also +/- 60V, +/-67V from PSU, normally this voltage will not make it go into protection if missing, just bad sound.
Check the gain settings are not set too high as it is clipping.. you should check the out put settings arent set too high to on the input side of thigs... you might be overloading
