1994 Yamaha XV 535 Virago DX Logo
A
Anonymous Posted on Jul 07, 2010
Sitting at a traffic light idling heard a loud ping!;bike wouldn't run any more ;turns over but wont start
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1260
Points
5
Sounds like a camshaft chain broke. remove camshaft covers and check the cahin on both cylinders.
1helpful
2006 v star 1100 classic w/ vance + hines slip on exhaust. I get popping at idle and decel (i'm thinking it just needs to be rejetted). The big problem, is when the bike has already warmed up (at least 5...
The popping at idle and deceleration (when the throttle is in the idle position) could be a lean mixture at idle.
A lean mixture sitting at idle for a long light would cause the engine to run hot.
Also, as the engine reaches operating temperatures, the idle will pick up.
I have a1998 cbr600f 39000 thous miles was sitting idling at traffic lights when this loud rattle suddenlly started coming from engine could it be the cam chain tensinor
Yes it could be, but it could be any number of things. The only way to be certain would be to hear it. Ask a mate who has some knowledge of bikes. Where the sound is coming from will give you an idea of the fault, but only an idea.
2006 vtx1300r runs fine but wont idle
Ethanol in the fuel will often lower a bikes idle speed. Honda gives you a simple screw to turn to raise or lower the idle speed on your motorcycle. it is part #10 on the following diagram. http://www.bikebandit.com/houseofmotorcycles/2006-honda-vtx1300r/o/m2927#sch410152 The black plastic knob is located on the left side of the engine, when you are sitting on the bike, under the carburetor. Try turning the knob 1/4 to 1/2 turn clockwise. This should open the carburetor just enough to allow the cycle to idle again.
1helpful
My 2000 r1 wont start, light an everything come on,press the button an the starter is all i hear. from timt to time the bike trys to start, but it just doesnt. bought the bike from the previous owner who...
If the bike had been sitting for a while and it was running but wouldn't hold idle, you likely need to remove the carburetors and thoroughly clean them. To confirm it's the carburetors you can use a spray bottle to spray a little gas into the carb throats and try cranking. If the engine fires up, your problem is definitely in the carbs; more than likely gummed up. Remember not to use steel objects if you're cleaning the jets because you will enlarge them as a result.
When Im sitting at a traffic light my car will bog down. I replaced the idle control module about 2 years back and didnt have any problems. Now its happening again. So I changed the air filter and I...
A bad throttle position sensor wouldn't cause those symptoms. Return it before you waste more money. Check the EGR valve to make sure it's fully closed at idle
1helpful
My 06 gsxr750 heat up really fast. Temp stays around 190 while ridind. When I stop temp jumps up to 219 and the fan cuts on. Antifreeze level looks good and hoses are tight. I can feel heat coming from the...
My bike is the same, It runs at exactly 100 degrees more than outside air temp, and at a light, or in stop and go traffic, it will go to 212 when the fans come on. It is like sitting on a blowtorch. But that is normal, Harley's run a lot hotter than that. Mine is an 02 S4 Ducati. Been like that since new. I avoid Daytona, the worst place on earth for bikes. They have an average of 1200 burned bikes every year. Sitting in traffic for hours, not moving. And the noise, my lord, get a stinking muffler on that pig!!! Hope this helps.
Wont keep an idle at stop lights or when sitting
Look at replacing idle motor on throttle body, it is a electrical solenoid $70
6helpful
2answers
Ttr90. starts easily and runs smoothly on choke. will not run smoothly or idle off choke. could this be bad gas? the bike has never been run hard, is stored inside and possibly suffers from infrequent use.
Remove and clean the carb. Sitting around can let the gas evaporate. This leaves a varnish residue in the carb. Remove the carb then remove the float bowl. Use a spray carb cleaner to spray into the jets and carb circuits. Remove the throttle screw and air screw and spray into the screw holes. The low speed idle circuit is the problem so concentrate on the air screw hole. Put both screws back where they came from and turn each until it LIGHTLY seats. Now back each screw one and one half turns. This is the factory setting. If the bike still does not want to idle, there is still some varnish or trash plugging up the idle circuit.
4helpful
Daytona 955i running hot
That is quite normal - these bikes run very hot and will typically reach temp where fan kicks in (103 deg C) while bike is sitting at idle, even if not particularly hot weather. Needs good airflow through the rad to keep the temp down.
Fortunately, when fan comes on it lowers the temp quite quickly.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
