Doubble check your wiring to make sure you did it correctly. Trace out each wire to make sure it is correct. Check that you start on the hot side of the start solinoid. Check your main fuse. You may need to check your switch with a volt/ohm meter to ID the functions.
Check where the water comes into the refrigerator and you should have a solinoid valve...maybe two...if only one...replace the valve, it is defective or has debris or dirt causing the valve not to work...if you have two solinoids then replace the one that feeds the water to the dispenser because it is defective. Bud
This seems to be a problem with you onbooard display. Without knowing what happen the last time you could see the screen, this would be my guess. With that in mind, you would need to replace the board or if the unit is still under warranty, have Asus repair it for you.
hello this means the solinoid is bad. inside the water box on top of electric water valve. shut water off at the street than unscrew solinoid there is two wires cut them than reconnect to new solinoid. look at wire colors so u know what solinoid is bad.
It would most likely be either stoped up somewhere or the solinoid that pulls a valve open to let the bleach out is not working. Could be the timer because it tells the solinoid when to work it may not be sending the voltage to the solinoid. I like the older machines they are built better.
Good luck I hop this helps
