20 Most Recent Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP Questions & Answers
Unfortunately a lot of Manufacturers like to cut corners when you have a refrigerator like that like the type that we had as well they don't come with trays to catch the condensing water it just doesn't happen dude so unfortunately you know you kind of got to make something yourself but that's the only advice I can give you but I hope it solves your problem it's not just peeing for no reason
Samsung 26.0 Cu.... | Answered on Feb 06, 2018
The evap coil freezing up is likely due to the defrost cycle not working. The little defrost t-stat looks like a little disc with wires coming out of epoxy. If that is swollen or the expoxy is popped up at all it's bad. You can check it for continuity if you have a multimeter. The next thing would be the defrost timer itself that is bad, the last and least likely item to fail is the heating element itself, you can also check it for the proper ohm value to make sure it's OK. http://www.partselect.com/Schematics/Maytag/SS50-8.gif
Samsung 26.0 Cu.... | Answered on Sep 07, 2017
Not sure if you have one or two problems, so need to be systematic. From what you say it seems you have a defrost heater problem.
Here is how I would start:
- Get a service manual for your fridge.
- Make sure you are not running the fridge in "sales" mode
- Run a self test of the unit (as described in the manual).
- Based on results, unplug the fridge and remove cover of the electronic compartment
- Remove the connector of the heater units.
- Measure the resistance of each heater to see if they are all good.
- If this is the case re-plug the connector and plug the fridge
- Using "force mode" described in the manual turn the heaters on and measure voltage on the respective connector.... this will tell you if board and built-in relays are good.
This should give you a good start of where the problem is.
Note than when in force mode you can also force the compressor to run in different modes and measure the related voltages. If the above does not get any hint, then moce your troubleshooting that way.
Samsung 26.0 Cu.... | Answered on Apr 05, 2017
does the freezer side freeze up also? i suspect if unit uses electronic sensors probably the thermostat sensors in the refrigerator section is defective. possibly there can be a thermostat board also you probably have to check diagrams.
Samsung 26.0 Cu.... | Answered on Jun 27, 2016
I don't know of any web site that you can go to but contact me and i can answer your question on the codes.
Samsung 26.0 Cu.... | Answered on Mar 25, 2016
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Samsung 26.0 Cu.... | Answered on Dec 30, 2015
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Samsung 26.0 Cu.... | Answered on Jul 26, 2014
check to see if the fan and compressor in the back conme on first. if they do then shut the unit off and remove the back panels inside and thaw out the ocils.
Samsung 26.0 Cu.... | Answered on Nov 04, 2012
Refrigerators Logo
120 questions posted
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
need register new samsung refrigerator
  • Refrigerators
