Yamaha P4500 Power Amplifier 2-Channel Logo
Posted on Jul 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
[email protected] yamaha p4500 amp one chanel not working. once in prog. amp brust up because of high voltage both chanels.... But we repair one chanel its working but chanel 2 not working
  • Anonymous Mar 18, 2014
    left chanel wire disconect from relay circuit relay on
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
644
Points
Yamaha p4500 amp one chanel not working.
Anonymous
Level 2:
An expert whose answer gotĀ voted for 100 times.
New Friend:
  • Expert 96 Answers
  • Posted on Jul 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
11957
Points
183
TURN THE BALANCE CONTROL IN THE MIDLE
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Amp wont work
Hi I have a Yamaha DSP 3090 Amp my right main Chanel is not working Amp goes off when i try to put the power on i think it goes on protction mode?after trying for 5to10 times it comes on, test mode all chanels work well not sure whats wrong ? can anyone slove my problem
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at [email protected]
thank you again
M.Fateh Almunajed
JVC dual channel bridgeble Amp
Most repair shops offer a warranty. If you've recently had it repaired, return it to the shop to have them check it out. If you continue playing it as it is, more damage may occur and the additional damage isn't likely to be covered by the warranty.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
