Computers & Internet Logo
Posted on Apr 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell reinstallation CD XP admin password
I am trying to RECOVER the XP system from my DELL CD that came with system. It starts okay, and I select "R" for Recovery and then it asks for the Administrative password.
I have entered both the BIOS Admin password (and also the XP Admin password (although I could not see how it would want the XP version). Also tried ADMIN and {Enter}...all fail and just get the C:\Windows command prompt...sweet!
Any ideas of suggestions appreciated. The system is a Dell Dimension 8400, and started getting a lot of BLUE SCREEN of death errors. Have tried reinstalling the 4Gb of Memory and a new hard drive (C:)....all to no avail...so, I was going to try and lay down the original XP operating system, hence the problem with the Admin Password request.
Thanks,
Mike
[email protected]
Chris Doty
Level 2:
  • Expert 81 Answers
  • Posted on Apr 19, 2008
Chris Doty
Expert
Level 2:
Answers
81
Questions
Helped
31493
Points
162
When you get to the command prompt use chkdsk to attempt the repair of your blue screen. Type this in the command line:
chkdsk c: /r
2answers
I do not have the username and password for my new Dell latitude 2120
There are 3 ways for you to reset Dell Latitude password. Let's specify them in 3 parts.
Part 1: Using a Password Reset Disk
When you create Windows user accounts for your Dell Latitude, you can also create a password reset disk at the same time with a USB flash drive or a floppy disk to reset forgotten password afterwards, which means you have to make this tool before you forgot Dell Latitude password. Meanwhile, this password reset disk can reset only local user account password. If you want to unlock dell latitude without password or disk, or your Dell Latitude is on a domain, please refer to Part 3.
Part 2: Reinstalling Windows System
If you have no password reset disk, Dell Latitude will suggest you to reinstall Windows system when you forgot password. However, the cost of reinstallation is huge because all your settings and data in C drive will be lost. If you don't want to lose resources on your Dell Latitude laptop, try the following method.
Part 3: Using Dell Latitude Password Reset (Reset Password without Disk)
If you want to unlock Dell Latitude (d620) without password or disk, Windows Password Recovery (Windows Password Recovery Tool) will be your best choice to access Windows 8.1/8/7/Vista/XP adminitrator in dell . It is specially designed to reset any local or domain account password without system reinstallation when you forgot password and can't log into Windows OS on Dell Latitude laptop. Here is the example of Dell Latitude admin (administrator) password reset. What you need is just a USB flash drive or a blank CD/DVD and an available computer.
Note: The steps to reset other user account password (no matter whether it is a local or a domain one) are the same.
  • Step 1: Download and install Dell Latitude Password Reset on the available computer.
  • Step 2: Insert a USB flash drive or a blank CD/DVD on the computer, specify the burning device, and click "Burn".
  • Step 3: Click "Yes" and "OK" button in the pop-up windows.
  • Step 4: Insert the newly created USB flash drive or CD/DVD on your Dell Latitude and reboot it. Select the Windows installation you want to reset the password, choose "Reset your password" and click "Next".
  • Step 5: Select the administrator account, choose "Remove the password" and click "Next". In the pop-up window, click "Reboot".
I forgot yhe administrator password and cant get in my computer. Not even to the start. Can you help me?
Kim Sovereign,
Dell does not have any Admin passwords to help you get into your system. You would need to purchase some software online to recover passwords are format and reinstall Windows. I have included a link to help you manually reinstall Windows below.
How to Manually Reinstall Windows XP
Drivers Download Page
Thank You,
Dell-Jesse L
Dell Social Media and Communities
1helpful
2answers
My dell xp wont reset
Forgot your Windows XP password? Don't worry about that. I have troubled the same thing before. I searched from internet and solved the problem. Now i want to share with you and hope it will really help.
Solution 1: If you have owned another available admin password, it can work. Just log on your PC->Click "Start"button->Control Panel->Add or remove user account->Select the account you want to reset->Change or Remove the password. Then the password will be reset.
Solution 2: You can use one of the password recovery software tool to reset the forgotten password. Here, i would like to introduce you one of them, which i have applied. It is really a good hand. That is Windows Password Reset . The process is following.
Step 1: Download the Windows Password Reset Deluxe from http://www.windowspasswordreset.net and burn a erasable CD
Step 2: Boot the CD into the ISO image which is provided by Windows Password Reset Deluxe
Step 3:BIOS settings
Step 4:Recover the Windows XP admin password.
It is an easy-to-use way to reset windows password.
You can have a try.
14helpful
5answers
Forgotten pasword for dell dimension 3000
If you want the quickest way, then I think you can take a try this password recovery software, a program which helps to reset Windows Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Your DELL Dimemsion is supported. Good luck!
34helpful
14answers
Lost admin password for dell 1545
Bios or windows ? Please tell us more info!
Such as BIos password,
1. Discharge to the Board
2. use BIOS/CMOS Password Recovery Tool from http://www.biospasswordrecovery.com/
Such as windows password,if you forgot that,you can try some reset password tools,I know three tools.
1. "Windows Password Recovery Tool 3.0"
http://www.windowspasswordsrecovery.com
2. "Windows Password Key 8.0"
http://www.lostwindowspassword.com/
3. "Windows Password Recovery 6.0" http://www.recoverlostpassword.com/
Help you to reset windows password if you have forgotten your password.
3answers
Tried to get rid of login screen - but it now demands a password!
BIOS passwords are removed by removing the CMOS battery temporarily from the motherboard. Windows passwords are reset with this CD: http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
12helpful
4answers
Forgot Admin Password for Dell Latitude D620
when i got my Dell Windows 7 admin password, I follow video tutorial to reset password easily:
http://www.youtube.com/watch?v=IDIyKd8dNrQ
1helpful
How can I get rid of Dreaded blue screen of death?
If you have 2 memory sticks in system, remove one and try it. If you have the green recovery disk that dell sends with their systems, place in drive and have it boot. Select "R" for repair drive. Then select "1" then enter your admin password. If you did not place one on system, just hit enter. Then at the
C:\WinNT directory, type chkdsk /r then hit enter, and have chkdsk look for drive errors.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
