Kenwood KDC-3027A CD Player Logo
Posted on Jul 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT CAR STEREO KEEPS GOING INTO DEMO MODE WHEN THE IGNITION GETS TURNED BACK ON
xxxxxx xxx
Level 3:
  • Kenwood Master 5,117 Answers
  • Posted on Jul 04, 2010
xxxxxx xxx
Kenwood Master
Level 3:
Answers
5117
Questions
5
Helped
1321071
Points
15645
It normally means that the permanent battery supply to the radio (that maintains all the memory features ) is missing
(The other battery supply is wired via the ignition switch and this is used for turning the radio on)
Check the fuse or connectors or wiring
1helpful
My stereo keeps defaulting back to demo mode
You most likely have the 12 volt permanent connected to the switched supply lead you need to identify which wire requires the permanent and the wire that requires 12 volt switched this will only appear when you turn your car key to acc position , it's normally a yellow or orange wire your looking for but check your models schematic.
1helpful
Demo mode won't stay off when I turn off the car
have a lookn on the wireing on the back of the unit. you should have 3 cables that are dedicated to powering the unit. one is 12v constant power, one is your ignition and the other your earth. ensure that your 12v power cable and ignition cable are connected up correctly.
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
My New KDC-314AM keeps going into demo mode when I restart my car eventhough I have cancelled the Demo mode
you'll notice a connector on yellow and red wire, these are battery connection and ignition.connect the red onto red and red onto yellow....thats it....it is also shown on operation manual, ISO CONNECTION option 2.
2helpful
Radio wont work, stuck in demo mode?
you put something in the blue input thing
that puts the stereo in demo mode
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Aiwa cdc-r30mp demo display
OK,
Please make sure Yellow wire (back up supply) is connected with Ever-12 Volt line (should not switch off with ignition) and press DSPL button to et display on clock.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
