In the adapter there are many tiny electrical components,.If any of the one goes short the adapter will stop working.,
Yes in some cases cleaning helps but there is a power input and output ports in the adapter.If any dust is see on that or the input port.In the input port there is a hole in the input port.Check out if any dust got collected and got stuck up in the input port.the other thing to repair is opening the adapter and checking the electrical components with meter.
But instead of repairing the old adapter the cost of replacement adapter is near to $10.
you can go for it.You can get the replacement adapter from the following site.Click on the link below
NES-Super-Nintendo-RF-Adapter-/310228165170?cmd=ViewItem&pt=Video_Games_Accessories&hash=item483b0a2232#ht_1491wt_754">http://cgi.ebay.com/Official-NES-Super-Nintendo-RF-Adapter-/310228165170?cmd=ViewItem&pt=Video_Games_Accessories&hash=item483b0a2232#ht_1491wt_754
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
there are some factor that you will have to put in to consideration concerning the wiring connections i will like you to look in the wire connection RF or the SERIAL depending on the wire you make use of on the connection but if the wires connection are well connected and in good condition (please note some wire go bad after been use for some time then return back to it )
it then mean that the adaptor is bad which you will have to replace
then you will have to replace the adaptor with a better one from the store then make sure that new adaptor should be is same form and value with the old one be sure of that when replacing the new one
thank you and thanks for using fixya.
Welcome to Fixya
Perhaps,it is a problem with the video cable. make sure the cable ends and the ports on the tv and consle are clean and connected properly.
Try it on another TV, make sure the AV switch isn't in wrong positon, try another lead like a SCART lead if you're not already.
Try switching it to another outlit or use the 3 pegs instead of the rf switch. Or try switching it to channel 4 or 3.
The connector for the cable..clean the game-Using alcohol...
ALSO CHECK THIS vIDEO HERE
Still have HAVE PROBLEM you need to Contact vendor /Repairer....Hope you got it....Thanks for Connecting FixYa...
Keith_brown0
It sounds like you are not getting a good video signal to the TV. Let me know that cable you are using to connect it to your TV. Also let me know the make and model and I will see what we need to do to get you up and running.
Issken
http://www.fixya.com/users/issken
model no: 003 its the original that came with the snes. I also have the one that I have just recieved with the other snes that one has the the red white and yellow prongs. I also just tried my RF adapter that can go into playstation, gamecube, and xbox. It works fine but when I tried it same problem black screen. I dont no if its just cus that one was not fully met for snes or what
keith_brown0
If you are having trouble with your XBOX as well then it does sound like a TV setting. Let me know the make and model of the TV so I can look up the info on it for you.
Issken
the RF model no: is nes-003 i have also tried the one that came with the one i just purchased it has the red white and yellow prongs but that doesnt do anything and i have to put that one in the multi out plus i just tried my one that can be used for gamecube playstation and xbox that also gives me a black screen that one could be just because it doesnt go with snes
If my old rf adapter can still work what is the best way to clean it?
