Hi, iv got a quattro, its been not used for a years or so, when i start it it revs up to 4k then dies after 7 seconds,.. iv replaced the fuel pump... i dont no what elce....
ed
Remove the air filter and squirt a bit starter fluid into the intake manifold , then immediately try to start the car if it starts , that is an indication there is no fuel going to the engine ,check the fuel system,if it does not start , you may have an ignition problem.
You need to have OBII scan performed. The fluctuating idle sinus like a MAF sensor, Temp & fan are separate issues. Get scan done, that should identify exact issues.
i would check the throttle butterfly for a carbon build up that may keep it from closing completely. have seen this cause stalling when returning to idle rpm. Best to try to remove and clean from both sides to get good results.this is just one of many possible problems. Hope it helps if so please let me know with a reply and good luck
i have a 2001 Audi A6 quattro 95,000 miles when i change gear the car seems to over rev or keep reving when i put my foot on the clutch for a split second chould you tell me why is this
Your V8 Audi has two necessary sensors that malfunction due to their placement in extreme heat on the lower left side of the engine just inside of the header/down pipe connection. They read the flywheel position for the engines computer ECU. The reference sensor is always suspect, but the speed sensor may need to be changed, as well. The wire connectors to the sensors that sit above the FL suspension can be tested, or just replace both sensors to get some quality time with your V8.
Could be the fuel pump. If there is pressure in the fuel tank, such as on a hot day it is just enough to get the engine to sputter a few times but not keep running. Might also be the cam position sensor (left rear side of V-6 engine ). A scan reader tool would indicate that.
