HP iPAQ h6315/h6365 Pocket PC Logo
Posted on Jul 01, 2010
Hp ipaq h6315 unlock code - HP iPAQ h6315/h6365 Pocket PC
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
5166
Points
31
Get the unlock code here http://www.wickedunlock.com/unlock-your-phone/rs11wp2/ and also get the unlock instruction in the same site....With the help you can unlock easily....
UNBLOCK
There is a code that is unique to your phone only. Search on eBay (ipaq 6315 unlock code) and buy the code for about $20. You will need to give them the IMEI number located behind the battery.
How to unlock hp ipaq 6315
Not sure you still need a solution for this problem, but this may help someone else who is searching for the same solution.
You need an unlock code. Each unlock code is unique to each phone. You can search on Google or eBay and find a seller. I got one on eBay for $20. You have to provide the IEMI code from the phone. It's on a tag underneath the battery. They will use the IEMI code to get your unlock code and email you the code along with the instructions. Read the instructions all the way through before you start. I was able to do it the first time and it worked.
2helpful
Power
when i plug my ipaq h6315 HP Pocket PC usb/charger into my ipaq it cut on but then cuts back off
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Hp ipaq h6315
If it is blinking red, it means that your battery is having issues. Try replacing the battery and see if it fixes the problem.
2helpful
Hp ipaq 6300
Get the unlock code here theunlockspot.com and also get the unlock instruction in the same site....
RE: HP Ipaq H6315
igot demage body as well as charging socket
how do iget it in india
ketan
Connect Flash drive to HP iPAQ h6315
Do you mean a USB "stick" drive? (i.e. like you use with a laptop or desktop?) If so, it won't work since the 6315 does not have a USB host capability -- Some other brand PPCs do support this function, but not HP. Sorry.
IR Printing for Ipaq H6315?
Try looking over here: http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/en/sm/network_software/mo bilepocket_overview.html?jumpid=go/pocketpcprint
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
